Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-23-2006, 09:09 PM
latham latham is offline
first car help
ok i just got my first car a 1995 pontaic sunfire 2.2 se
and i was wondering about these intakes
http://cgi.ebay.com/ebaymotors/95-97...spagenameZWDVW
are they worth it?
also what size is my headliner bulb?
whats the best way to get the moon ring out of my window handle?
also my back passengers side turn signal is not working the light in the insturment panel lights up but does not flash any advise?
i think thats it thank you im srry wi dont know much about cars im only 15
Old 01-24-2006, 10:52 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: first car help
Welcome to AF!! I don't know the bulb information, check autozone online and you should be able to find out. The intake is worth the money and it will give you more performance. The key it to try to get it into air that is free flowing and is cold as possible. The ring on the window handle actually takes a special tool to remove. You can probably find one at JC Whitney or check the local parts store. As for the flasher make sure that all bulbs work. If not you will probably need to change the flasher unit. Finally, one word of advise, purchase a Chiltons or other manual relating to your car since it will help you with your questions. Amazon.com has them for about $20.
Old 01-24-2006, 07:33 PM
Re: first car help
ok thx i think i got all my info now i read a post about the moon ring and it worked.all you have to do is take a toweland run it through under neath the handle exp.
handle > ( ) ^ < towel
II !
II !
(0) ^
the bulb is a 562 but they dont sell them at walmart
thank you very much
