Old 01-23-2006, 06:25 PM
Camaro84 Camaro84 is offline
high or low volume pumps
I Have a new high volume pump but a few people said i should just put my old one in if i dont want to go get a new stock pump..... wat do u Guys Think
Old 01-23-2006, 07:43 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: high or low volume pumps
What kinda pump? Mechanical or electrical and for what application?
Old 01-24-2006, 01:04 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You don't NEED a high-volume pump unless you're turning the engine above 6,000 RPMs, but in my case I went with one when I built my current engine in '93 and used a normal pressure relief spring. A quarter million miles later, it's still the bomb. Make sure that you use a stainless steel driveshaft if you use a high volume pump.
Old 01-24-2006, 10:22 PM
Banned
I wont agree with this. I prefer a high volume electric pump over a stock one simply because they are better and are more reliable to put out ideal fuel pressure. A nice fuel pressure regulator, and two pumps (one pushes the other delivers fuel), just like older bimmers do. No more crapy whining,or fuel stravation, etc.
Old 01-25-2006, 12:22 AM
RahX RahX is offline
i think this is about oil pumps?
Old 01-25-2006, 12:51 AM
silicon212's Avatar
Confoundingly Lucid
I'm talking oil pumps here, not fuel pumps. If fuel pumps are the deal, then ...
Sorry, years of engine building.
Old 01-25-2006, 02:43 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
If you install a high volume pump, you may want to add an extra capacity oil pan, to prevent sucking the pan dry.. I'd hate to hit 5-6,000 RPM and have the pump suck air...
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-25-2006, 10:06 AM
silicon212's Avatar
Confoundingly Lucid
Good advice, especially on a higher-mileage engine with larger bearing clearances!
