Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-23-2006, 06:02 PM
Willyswagn Willyswagn is offline
running problems with 89 suburban
I'm looking at an 89 suburban on the internet with the following problems. Anyone have any ideas? A sensor problem?
Note: The truck will start. It will stay on with no problems, on Idle. Sometimes, when shifted into gear it will shut off and have a hard time starting. It will crank and crank, but not start. Then all of a sudden everything is o.k.
Old 01-23-2006, 06:45 PM
2000CAYukon 2000CAYukon is offline
Re: running problems with 89 suburban
Tough to diagnose with your description. For example, how is the idle quality? Too low, too high, can you feel a miss, etc.
Things that can cause the problem:
1) IAC - controls idle speed based on PCM commands
2) MAP Sensor - affects fuel delivery based on vacuum
3) Fuel pressure
4) EGR valve and/or solenoid
5) Ignition coil
6) Ignition module
7) TCC Solenoid sticking - locks up torque converter and engine stalls when put into gear
It is easier to diagnose if you know if the problem is ignition or fuel when it won't start.
In general the TBI engines are fairly reliable and easy to work on. The only time my 90 K1500 truck left me stranded was when a MSD ignition coil failed on me.
//2000CAYukon
