Old 01-23-2006, 04:54 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
Gasket HELP!!!
I need to know which Gasket I need to replace and what parts exaclty that I am going to need to replace it.
I have a 1995 Grand Am GT 3.1L 3100. Right now the car is sitting but I needed some help. My Coolant Is mixing with my oil and I don't know what Gasket that it is? Can I drive it to the place where it will be getting fixed at? PLease Respond ASAP. Thanks!
Old 01-23-2006, 05:44 PM
Hoags's Avatar
Hoags Hoags is offline
Re: Gasket HELP!!!
Most of the time when you have oil and coolant mixing it is a result of a bad head gasket, on the 3.1L V6 you will have 2 heads and head gaskets, unfortunatly most of the time it is not easy to tell which side is causing the problem.
Depending on how bad the leak is will dictate weather or not you can drive the car. Is it blowing a lot of smoke out of the tail pipe? and how far do you have to drive? Is the temp guage climbing? All of this will tell you if you can drive the car or not.
Old 01-23-2006, 05:56 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Gasket HELP!!!
Unfortunately, I have to disagree with Hoags this time. Most of the time on the 3.1 or 2.8 when you get water mixing with the oil you will need to replace the lower intake manifold gaskets. To get to these gaskets you will need to remove the upper phlenum and the throttle body and a host of other parts. I would get a manual either chiltons or haynes before even attempting it. If you have white smoke coming out the exhaust then the head gaskets will also need to change them like Hoags said!
Old 01-23-2006, 06:16 PM
Re: Gasket HELP!!!
no, it starts like normal and everything. It's just the coolant is mixing in with the oil, no smoke though.
Old 01-23-2006, 06:58 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Gasket HELP!!!
water in the oil will destroy your engines ability to lubricate its self properly, and can ruin the motor! Id get it towed to be safe.
1999 Grand Am SS 3.4 OHV
Old 01-23-2006, 08:42 PM
Hoags's Avatar
Re: Gasket HELP!!!
Hey GTP Dad, I'm allowed to be a little off, however I did take the assumption of the smoke out of the tail pipe, that has been my experience when I've had oil/coolant mix. But your probably right it has been a while since I have had to deal with that (knock/knock/knock).
