Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-23-2006, 04:36 PM
reggiestewart reggiestewart is offline
Question odd oil pressure problem
A friend of mine just called me with a seemingly odd oil pressure problem in his 97 wrangler 4L. He says that, as he's going down the street, his oil pressure will drop dangerously low, sometimes all of the way to zero. He pulls off the road and the oil pressure comes back at idle? My first thought was to test the pressure with a mechanical gauge, but if his guage reads normal at idle, that may not tell us anything. He's got plenty of oil, the motor doesn't tick, and temp stays normal. does this sound like a sending unit? pump?
Any suggestions would be greatly appreciated
Reggie
Old 01-24-2006, 09:15 PM
GreenJeep10's Avatar
GreenJeep10 GreenJeep10 is offline
Re: odd oil pressure problem
Check oil sending unit. I went to a mechanic to have it checked and he started talking about main seal leak and that I would need a new engine costing around 3-4 thousand and he continued and I stopped him and said. Could it be the oil pressure sending unit. He said we could check it and low and behold it was a $50 sending unit. I had same problem at idle the pressure was around 40 but going down the road a ways it dropped to 0. No ticking pinging or other problems just the gauge on the dash. The sending unit is on the passenger side of the engine toward the front. I have a 97 4.0L Sahara so I hope its the same problem. Quick and inexpensive fix.
Old 01-26-2006, 04:12 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I had a similar issue on my 1995. When I was driving the pressure gauge was reading all the way up. When I'd put the gas to the floor it would read the correct pressure. It was a $35 pressure sending unit.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 01-26-2006, 08:03 PM
nick0750's Avatar
nick0750 nick0750 is offline
the oil pressure sensor from jeep is pn 56031003 $73.75
Old 01-27-2006, 04:45 PM
Search Results: OIL SENDING UNIT
Click "Buy Online" beside the item you'd like to purchase from AutoZone.com.
Click "Add to Store List" beside the item you'd like to add to a shopping list that can be sent to and paid for at your preferred AutoZone store.
OIL SENDING UNIT for a
1995 JEEP WRANGLER 4WD
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
NIEHOFF OP67871 $20.99
1995 Jeep Wrangler
4.5L stroked I-6
Jet Chip Stage 2
Jet Thermostat
