Wont start
I have a 93 gp 3.1 that wont start. Have replaced crank sensor, ign module coil packs. ecm. car had a/m remote start system, removed. Chkd fuel pressure also 44psi at rail. just no spark. any help would be greatly welcomed. daughters car needs for school.
Re: Wont start
Checked all the pcm and ign fuses?
Re: Wont start
Re: Wont start
Get a scanner on it and look for cranking rpms, if none suspect wiring from crank sensor to icm since both have been replaced, also make sure the icm is getting 12v.
Re: Wont start
Did the car start before the Remote Start system was removed?
Re: Wont start
Yes the car would run before removing remote start. Ran ok afterward also. Did more checking voltage to icm good. no signal at icm. replaced again, car runs fine now. Thx for all the help.
Re: Wont start
That's awesome!
Re: Wont start
More AZ parts??? I'd get a bill for labor and make them reimburse you for that, NAPA does.
Re: Wont start
No actually the new icm came from NAPA this time. Got frustrated at AZ. Test equipment is not really accurate.
