Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-23-2006, 02:15 PM
sureshot1342 sureshot1342 is offline
92' pick-up leak.
i have been noticeing some water in the base on my single cab pick-up. The carpet was actually pretty wet. Now ive done some searching, sealed the front and back plugs. However im wondering if my heater block is clogged and water is channeling in through there. The wettest spot is passenger side front.
any ideas guys thanks.
Old 01-28-2006, 08:21 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
Re: 92' pick-up leak.
Almost definitely is your heater core.
WAR UTAH!!
Old 01-29-2006, 06:46 PM
KimMG KimMG is offline
AF - Advisor
Is it fresh water or coolant? Do you have coolant in your cooling system? Check around your fresh air intake for the cab, it maybe clogged with debri and not draining. Do you have air conditioning? A/Cs cause a lot of condensation and if the drain tube is clogged, it will leak into the cab. Check to make sure your windshield seal is not leaking.
Old 01-31-2006, 06:11 AM
RWarrior RWarrior is offline
Where do you come from? Here in Quebec, unfortunatelly, many times it happens it's because the rust on the windshield flange... We use salt to de-ice the roads... It cause bad rust on the cars
Old 02-01-2006, 07:15 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Yeah had that problem on my 83 p/u. Every time it rained hard there'd be a puddle on the pass side floor. Leak at bottom of windshield was the cause.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
