Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-23-2006, 01:58 PM
giosong giosong is offline
toyota camry 91 intermittent not able to start
I have a 1991 Camry that sometimes all of a sudden doesn't start. It does act like it has no power (no cranking from starter, no mechanical noises).
Sometimes it restarted after a few attempts but sometimes battery needs to be jump started. And the battery is new.
Once it runs, it does not die at all.
I will truly appreciate any advises. Thanks very much.
Old 01-23-2006, 11:59 PM
ProMan ProMan is offline
Re: toyota camry 91 intermittent not able to start
2 possibilities
1. the neutral switch is bad. The battery voltage drops at there and can't activate the starter.
2. internal contact points of the starter are worn.
Old 02-09-2006, 11:49 PM
mystic67 mystic67 is offline
Send a message via MSN to mystic67
Two other possibilities are:
1) faulty ignitin switch
2) faulty ignition relay
I would put my money on the ignition relay.
Have you tried using a jumper wire from the starter to the positive terminal on the battery?
Old 02-10-2006, 12:01 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I betting with Proman. The starter (solenoid) contacts are a common problem and will give the symptoms as you described them.
See the post in the FAQ thread:
http://www.automotiveforums.com/vbul...86&postcount=4
Before you get too wild, check the battery, starter, and ground terminals for cleanliness and tightness. Have to be a good connection.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
