Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-23-2006, 01:35 PM
the_game_rock's Avatar
the_game_rock the_game_rock is offline
Turbo kit help
im going to get put a eclipse turbo on my car 2.0 dohc what would I need to do (to besides pistons and rods) to run about 12 psi? whats a good kind of pistons and rods? to get I was thinking je
Old 01-23-2006, 06:24 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Turbo kit help
I'd stick with the JE pistons and Eagle rods and new rings. They are proven on the neon and have proven durable.
You are aware that there is more to turboing a car than just putting the turbo on, right?
Old 01-23-2006, 08:28 PM
Re: Turbo kit help
Yes I do know I have been researching this for a little while now. I was told that a eclipse turbo would work good on it b/c it spools fast. What do you think? I know I would need bigger injectors fuel pump all the lines of course the turbo im sure theres alot more things but I cant think of at the moment. Do you know a site that goes in depth with turboing a neon and all the stuff I would need to buy?
Old 01-24-2006, 08:04 AM
Re: Turbo kit help
Well Hahn uses the Mitsubishi turbo because they say they are the best in the market, so I think your good.
This isn't in depth, but the post should help you with what you want to know. Also there is a book called Maximum Boost by Corky Bell that you might want to look at.
http://forums.neons.org/viewtopic.php?t=187274
Old 01-24-2006, 11:18 PM
Re: Turbo kit help
http://cgi.ebay.com/ebaymotors/95-42...spagenameZWD1V What do you think of this kit? What else would I need to get besides oil lines fuel pump, bov, and intercooler piping? How much would everything be besides whats in the kit?
Old 01-25-2006, 07:59 AM
Re: Turbo kit help
Looks good, but I would have a hard time buying a kit from an unknown source.
Did you read the post that I gave you the link to? It pretty much covers what you would need. All in all, you'd probably spend another $700-$1000. Turboing a car is not cheap if you do it right!
Old 01-25-2006, 10:52 AM
Re: Turbo kit help
Yea, All in all thats not too bad ill probably do it in a few months when my wife gets another car so I can work on mine since Im going to get pistons too. Im was thinking a stage 2 spec clutch would work well what do you think?
Old 01-25-2006, 11:48 AM
Re: Turbo kit help
I have heard some good things about them, but for my money, if I had any, I'd go with Clutchmasters or Centerforce.
Old 01-25-2006, 01:34 PM
Re: Turbo kit help
wheres the cheapest place to get clutchmasters? I need a stage 2 right? I heard if you put centerforce with a fidanza flywheel they break.
Old 01-25-2006, 02:12 PM
Re: Turbo kit help
Modern has it for $460 and you would need a Stage 3!
Old 01-27-2006, 09:37 PM
Re: Turbo kit help
All I have as now is a header and intake and getting ready to put on a flywheel I wont be getting a turbo kit for a few months I have to get a clutch now though should I get a stage 3 now or would if be bad off on my car?
Old 01-28-2006, 12:24 PM
Re: Turbo kit help
You will be fine with the stage 3 for now and when you put the turbo on.
Old 01-28-2006, 07:46 PM
Re: Turbo kit help
whats the pros and cons of a stage 3 clutch? (besides take off)
Old 01-29-2006, 09:26 AM
Re: Turbo kit help
Pro - can handle up to 300HP
Con - $460
Old 01-29-2006, 09:04 PM
Re: Turbo kit help
Con - $460
I thought they handle more than 300
