Old 01-23-2006, 12:33 PM
escort_jay102 escort_jay102 is offline
Stock Air Filter Black Box!
I have a 93' escort LX w/ a 1.9L. I heard that if I took the Air Filter Housing and make a bigger hole in it at the bottom that I would gain more mileage? And if so, then how do I go about making a hole in plastic like that?
1998 Chevy Cavalier
2.2/ K&N/ Ractive muffler
1994 Chevy s10
thrush welded muffler
Old 01-24-2006, 10:19 PM
josh_jonze josh_jonze is offline
Re: Stock Air Filter Black Box!
i would throw out the air filter box and just add on an aftermarket filter. you could find them cheap at auto zone or where-ever. or if you want to spend morei would just put on a cold air intake. you will get more horse power and TQ. it makes your gas mileage really good to.
Old 01-25-2006, 06:45 AM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Take the air box off and put it upside-down on a bench. take a drill and drill a serious of holes around the larger side of the air box.(as you will see its split 70/30ish). Then cut the pattern out. nice big air hole for the car to breathe. Also, take out the air silencer while your at it(the tube that goes onto the pre-made hole there in the air box. Just use a filter and you'll be good to go. Takes about 30 minutes start ~> finish and works great.
Or you can go spend (GOD only knows how much) and do what the above poster said..but with cutting the bottom of the air box, it does the same thing. I did it because I had access to a drill and it cost me zero $$ in doing so. Its your choice.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 01-25-2006, 08:55 AM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
easy way...hacksaw
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
