Old 01-23-2006, 12:13 PM
jimakers jimakers is offline
Blinking Temperature Display
I have a 94 LeSabre Limited with the electronic climate control system. Recently, it has started have problems with the temperature display blinking, whether the system is on or off. Does anyone have any idea what could cause this?
Also, does anyone know where the control module for the vents is at? System has been stuck in defog mode and I can't seem to get out of it.
Thanks for any help.
Jim
Old 01-23-2006, 01:11 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Blinking Temperature Display
Jim
Does it go to heat mode at all when you push the button for that? It may be the vacuum tubes at the programmer sucking shut the connector nipples since they soften with age. That can be bypassed by checking which color inside the programmer goes to which color outside and connecting the two with 1/8 inch gas line pieces about 1 inch long. I did it. Links are out there if I can find them again. I think it's at imcool.com as in air conditioning/radiator shop supplier.
There is a diagnostic that I believe works for 94 and lower.
Diagnostic mode:
Auto Climate Control Diagnostics
This procedure will work on 1992 and 1994 models with ATC, and may possibly also work on 1988-1991 models.
The diagnostic mode also contains a data list mode and an override mode.
Be careful not to select modes 01 or 02, as these are different modes, and may cause problems.
If you suspect you are in the wrong mode, press OFF repeatedly until you exit to normal mode. If the temperature display flashes for 2 minutes when the ignition is turned to RUN, a trouble code is set.
1. Turn ignition to RUN. Press OFF and WARM (temperature up) buttons simultaneously.
2. Watch the segment test, then the trouble codes will be displayed.
3. Code Key:
00 - No codes
10 or 110 - Ambient Temp Sensor circuit open or shorted.
13 or 113 - In-Vehicle Temp Sensor circuit open or shorted.
15 or 115 - LH Solar Sensor circuit open or shorted.
35 or 135 - Data Line failure - HVAC Control Assembly
38 or 138 - Data Line failure - PCM
40 or 140 - Driver Air Mix Motor circuit open or shorted, or not calibrated
48 or 148 - Long Term Freon Loss
52 or 152 - Keep Alive Memory lost; sets with battery disconnected
66 or 166 - Low Freon
A number 1 prefix indicates a history trouble code
4. Press OFF twice once codes are displayed to end diagnostic mode, OR to clear trouble codes, press FAN DOWN three times (make sure 03 is displayed).
Once 03 is displayed, press FAN UP to clear trouble codes. Then repeatedly press OFF to end diagnostic mode.
Old 01-23-2006, 02:51 PM
No, pressing the HEAT button does nothing. Warm air (or cold as is necessary) comes out of the defrost vents and lower vents, mixed, as in defog mode. Can't get anything to the panel vents, or singly to either the defrost or floor vents.
Thanks for the info; will try to get a trouble code out of it.
JIm
Old 01-24-2006, 08:50 AM
Unhappy Re: Blinking Temperature Display
Just an update.
The diagnostics posted above DO NOT work on the 94 LeSabre.
Old 03-07-2006, 01:19 PM
Question Re: Blinking Temperature Display
Anyone else have any ideas?
Old 03-07-2006, 06:06 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
You will need a scanner to check the codes on the 94 ACC. You can still reset the codes using the old battery ground cable disconnect trick, after you fix the problem.
The blinking of the control panel is telling you that is setting a code. Your code is more than likely for the actuator that is located on the passenger side behind the glove box. You can buy them at Advanced Auto Parts for about 36 bucks. It looks like this;
Old 03-08-2006, 08:44 AM
Thanks for the info. Unfortunately, this vehicle is one of those with the OBD "1.5" system, OBD II connector but is still an OBD I system. Finding a garage with a scanner, other than the local GM dealer, is a real pain. Will try this actuator.
Old 04-02-2006, 08:48 PM
David DeVoe David DeVoe is offline
I also have this problem on my 94 and have done the following; Lower the glove box all the way down to check the actuator motor. You can here it if it is running when you turn on the system. Also you can dissconnect the lever going to it and move it manually to try to redirect airflow.
My problem seems to be with the dual zone crap because I get cool air on the drivers side and hot air on the pass side of the car. Does anyone know what controls the dual zone system?
