Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 01-23-2006, 11:10 AM
kayyakker kayyakker is offline
Angry A/C, Heater Blower Works only on High
I have replaced the heating element with the resistor already and it worked for a couple of weeks and then quit again. Does anyone know what is causing the resistor to blow?
Old 03-01-2006, 01:33 PM
RedDiablo RedDiablo is offline
Re: A/C, Heater Blower Works only on High
I have the same problem, Can you tell me where the resistor block is located? Thanks
Old 03-01-2006, 02:03 PM
the resister is located on the passenger side just above where the passenger's feet would be located if they were sitting there. you have to remove a panel to get to it, and then you'll see wires going upward into the resistor block. just take the 2 screws out and it pulls right out. it will cost you about $25 at the dealer, which is the only place i could find one.
Old 03-01-2006, 02:15 PM
Smile Re: A/C, Heater Blower Works only on High
Thank you very much for the fast reply. I will get on it right away.
