Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-23-2006, 10:23 AM
abebesheir abebesheir is offline
when to replace shocks?
I have another quick question. My 1991 9c1 still has the original shocks at 123,000 miles. If it rides a bit rough, should I have them replaced and what's the best brand to go with? Thanks.
Old 01-23-2006, 01:21 PM
CD Smalley CD Smalley is offline
Re: when to replace shocks?
I would definitely replace them given the mileage. What brand is up to you. Bilstiens are quite popular on the 9c1 email list. But I think most people get the models for the 90 9c1 to imporve handling....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 01-23-2006, 01:41 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I've got Monroe Sensa-Trac's on my '91 9C1, I like 'em!
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-23-2006, 07:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I generally replace shocks every 15k miles or so. I like to keep them fresh. You should replace them every 30-35k miles. Bad shocks will cause a dangerous driving condition that can easily result in the car "getting away from you" during moderately high-speed (40MPH+) driving on a rough road.
Ditto Corning_D3 - I use the same shocks and love 'em!
Old 01-23-2006, 09:08 PM
silicon - You replace your shocks about once a year then? Are you replacing them with standard or gas shocks?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 01-24-2006, 12:38 AM
silicon212's Avatar
Confoundingly Lucid
Gas shocks. Once a year, generally in March.
Old 01-24-2006, 05:39 AM
I'm curious as to why so often? I could almost see replacing standard oil shocks that often. But I've run some gas shocks for well over 100k before they showed any ill effects.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 01-24-2006, 05:48 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
How hard is it to replace them yourself? Mine are shot - I still have the factory shocks with 134,000 miles on them.
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 01-24-2006, 06:43 PM
silicon212's Avatar
Confoundingly Lucid
You'll have to jack the car up high enough to allow them under the control arms. For the front shocks, there's a stud on the top that goes into the frame of the car, the nut is accessible from under the hood, look in the area of where the upper control arms attach to the frame - you'll see it. Remove this nut. This can be tricky as the shock shaft coult turn with the nut. I've found that a strategically placed set of Vise Grips helps with this. You'll need a 9/16" deep socket here. There are also two bolts that attach the bottom of the shock to the lower control arm. These require 1/2" sockets (more properly, 13mm sockets) to remove. Once you get these bolts off, the shocks should drop through. The new shocks will want to extend fully once you go to install them, you'll have to muscle them up in order to get those two lower bolts back on. Once on, you can attach the nut to the top stud (make sure you use the new bushings that come with the shock). You should not have to use Vise Grips when tightening this nut. Tighten only until the bushings start to distort, no more.
The rear shocks are easier. There's two bolts on the top that attach to the frame and a large bolt/stud for the lower attachment point. I cannot stress how much easier it is to replace these than the front! Make sure you use the new bushings and you will still have to fight the new shocks a little to compress them to the point of being able to install.
Old 01-24-2006, 07:38 PM
Cyrix_2k's Avatar
Hmm, so maybe I should just replace the rear shocks myself and get my mechanic to do the front... how hard is it to compress the shocks? And if I can't get them on, would it be possible to drive the car to the mechanic (a couple of miles at low speeds) with either the front or rear shocks missing? I'm just afraid of not being able to get the new ones on.
Old 01-24-2006, 08:09 PM
silicon212's Avatar
Confoundingly Lucid
You just simply push up on them. If you let them go, they will extend.
Old 01-24-2006, 08:13 PM
Cyrix_2k's Avatar
Cool. Any recomendations for cheap shocks? Thanks
Old 01-24-2006, 08:58 PM
Yep, don't use cheap shocks...
Old 01-24-2006, 10:04 PM
Cyrix_2k's Avatar
