Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-23-2006, 09:51 AM
zilly1 zilly1 is offline
coil pack problem help
hi i need some help i have replaced the coil pack for 1 + 4 twice the car runs fine for a few hours and the coil goes i am not sure what is causing this to happen what else should i check or replace help
thxs
Old 01-23-2006, 05:51 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: coil pack problem help
Welcome to AF!!
When you say it goes do you mean that it fails and the car won't run or it shorts out? There are two items that you need to check. The plug wires can cause a coil to go bad but they would have to be really bad to cause a coil to go out that fast. Second, the ignition module under the coil may be the problem. I would change the wires and the ignition module to see what happens. Try the wires first, cheapest then the ignition module.
Old 02-16-2006, 09:30 AM
thinman182 thinman182 is offline
Pull wires off ignition module while running and look to see if there is spark from the 2 bad ones. If no spark, change the ignition module because it is no good. Had same problem with mine.
Old 02-16-2006, 11:08 AM
jdq jdq is offline
Its easy to change and they are cheap at the wreckers
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
