Turboed Zc at the Track
Ok this past weekend I was out at the track with my 90 CRX Si with a ZC Turboed.
Unfortunately there were a few things wrong with it. For one there is a leak in the exhause manifold and I think there is one else where to. Because of the leaks (I assume) I couldn't boost over 4psi. I had borrowed a boost controller and havign it set to maximum boost I got it bumped to 5psi. I only had the boost controller for the first day and my best run was on the second day. This was the first time I had ever been to the track. We were running a .400 Pro Tree Here are two slips. This is my first run ever: R/T: 1.120 (totally unprepared) 60: 2.778 330: 7.290 1/8: 10.768 MPH: 73.66 1000: 13.622 1/4: 16.050 MPH: 93.27 This was my best run: R/T: .840 (still sleeping) 60: 2.391 330: 6.488 1/8: 9.913 MPH: 70.31 1000: 12.896 1/4: 15.377 MPH: 91.31 Now I not exaclty certain on the elevation but I was told the correction is .4 so if that is true then I guess I technically ran a 14.9. Also it was 35 deg Celcius out, not sure on farheinheit. My main problem is hooking up and actually getting moving. I was always getting wheel hop (chattering) at the beginning and my RPMs would like drop to 2000 and it take me forever to climb out cause I don't have any pwer until like 5500. My best run I dropped th clutch at 6000 it hopped a little but then the tires slipped and spun for while and i kept my rpms up. I think I could have pulled a little better ET maybe a 15.0ish but I dunno that is what a some ppl were saying with my MPH i should have been pulling better. SO what do you guys think? |
The second run sounds decent to me.
Now all you need is a new manifold, and a ZEX kit to spool up your turbo
Thats what my friend with a 100 shot in his truck is saying....but I think I will stick with just turbo for now....
Pio
Speed Up Or Get Out Of The Way SICKWITHITRACING <aim |
a turbo'ed zc should be way better than that, even at 4psi..... fix your leak and work on your launches, or get that z-10 bar and kiss your wheelhop goodbye.
formerly "riceboi" back at ph 1990 Crx Si ..b16a1 ...i/h/e ...PYR Racing head..ctr pistons .. ...flywheel ...stage 2 clutch ...3.5 drop on Ground Controls ...Koni adj's all around ... ...mugen kit ...sloppy yellow paint job ...apex'i vafc ...gsr brakes ...gsr seats ...autometer a/f gauge ...and more crap that nobody cares about |
1997 Toyota 4Runner Limited Built ZC in 90 Civic std model.... ![]() as marked001 says Don't click here |
it stiffens up your front end a lot |
Sounds great but a little pricey.....definately a future upgrae though
