Old 01-23-2006, 05:09 AM
d4h8a1's Avatar
d4h8a1 d4h8a1 is offline
Send a message via Yahoo to d4h8a1
bushings and ball joints
My '88 CRX Si needs all new suspention bushings and ball joints. Where is the best place to get these? I also need engine mounts, can i get a package with all the rubber under the car as well as the mounts ?
Old 01-23-2006, 06:49 AM
Hybrid1990crx's Avatar
Re: bushings and ball joints
look up 'energy suspension bushings' and you'll find everything you need.
Old 01-23-2006, 02:01 PM
dagoEF's Avatar
dagoEF dagoEF is offline
I got a package of Ebay that included lower ball joints, complete upper control arm, sway bar end links, inner and outer tie rods for around $130. That doesn't have the bushings, but it was a good deal. The parts worked well OE fitment.
Old 01-23-2006, 10:32 PM
Cmdridq Cmdridq is offline
Just curious, did your engine mounts just break, or what? Is there something that causes them to break?
Old 01-23-2006, 10:58 PM
skotman's Avatar
skotman skotman is offline
since the engine is constantly vibrating, the mounts can't be rigid or the whole car would shake. you only feel a fraction of that through the steering wheel and frame when you drive.
anyway, the mounts are a circular metal mount with a rubber core and a place to put a bolt through.
rubber deteriorates over time no matter how well you take care of it. the mounts could actually have been cracked for several years if they've never been replaced. there was not a very noticable change in performance after i replaced mine.
replacing them doesn't take a whole lot of technical knowledge or a lot of time if you know what you're doing.
Old 01-24-2006, 10:13 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
I just wanted to add that I had the poly motor mount inserts in my car for a few months and was annoyed by the vibration. I pulled them out and bought an new OEM front mount (this was the mount that was cracked the worst) and I'm happy with it now. I also bought and installed most of the energy suspension bushings in the master kit and did have to buy the rear trailing arm bushings seperate and I'm happy with them as well.
