Old 01-22-2006, 10:23 PM
RCAID99 RCAID99 is offline
Smile 90 LUMINA 3.1 trans. problem
it has more than 150,000 miles and it just wont shift out of first gear i unplug electrical wires from it but still the same, fluid looks and smells ok. Any help or ideas before giving up, thanks guys...
Old 01-23-2006, 09:17 AM
maxwedge maxwedge is online now
A990 racer
Re: 90 LUMINA 3.1 trans. problem
Make sure you have vacuum to the modulator on the trans, 2cnd also scan it and check the tps for proper operation.
Old 01-24-2006, 12:33 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Have you tried shifting it manually, putting the shifter in 1, then moving it to 2, etc...? If it shifts manually, then the vacuum modulator is the problem.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-25-2006, 07:54 AM
Carwhiz Carwhiz is offline
Transmission filter would be my first step if it hasn't been changed yet in the last 50K. It should be due anyways if your car has 150K.
