Front end problems 96 grand caravan
ok here goes changed tie rod ends changed all links and bushings changed ball joints Problem still there1.clunking noise when turning steering wheel 2.vibration through the wheels 3. pulling to on side Have not had the alignment done in a while Question is can cv joints cause these problems? I'm down to changing them or the strutsThe cv joints do seem to have play in them but not making the classic popping or clicking noise.Everything else seems tight up front except the play in the cv joints Any suggestions before i waste anymore money thank you
Re: Front end problems 96 grand caravan
CV joints can make the noise you describe especially if you have play in them. I would replace the axle shafts as I believe that is your problem.
