Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-22-2006, 07:18 PM
TreStringz TreStringz is offline
Send a message via AIM to TreStringz
Breath life into old Engine
I have a 90 integra LS with about 170,000 miles on it. The engine sounds tired. Should I overhaul it? New pistons? Valves? Pulleys? Cams? Or should I just get a rebuilt motor. Whats is the most cost effective? I am not build a track car. Just something reliabe and quick
Old 01-22-2006, 07:40 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Breath life into old Engine
it'd cost less to do it yourself, plus if you want to build it up a little to get some more power out of it, nows the time!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-22-2006, 09:00 PM
ruffio1842 ruffio1842 is offline
Send a message via AIM to ruffio1842
yea defintaly do it yourelf. ull screw up a couple of times but ull learn alot. but u will probably need professional help for some things.
Old 01-22-2006, 09:01 PM
i.e. don't bite off more than u can chew.
Old 01-22-2006, 09:48 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
did a compression and leakdown tell you that, or is that an assumption?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-23-2006, 07:48 AM
Schister66's Avatar
AF -Advisor
^^I think he's telling you to do a compression and leakdown test before you decide to tear a decent engine apart......
Old 01-23-2006, 06:11 PM
How much does that cost? My engine squeaks like a hamster wheel or something. I think it may be a piston bearing or something Plus my Idle bounces around. It only loops before it warms up but after it warms up the idle bounces around maybe 100 rpms or so....It's just not steady.
Old 01-23-2006, 06:31 PM
WReX WReX is offline
the squeaking might be a belt or pulley, which is normal for a older engine
a compression and leakdown will probably run you what ever a shop charges for an estimate, but that will give you a very good look into your motor
26 PSI anyone?
