Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-22-2006, 07:10 PM
chevyguy502 chevyguy502 is offline
Send a message via AIM to chevyguy502
ASAP! timing?
my caprice has been running hot lately. like 230-240. I was coming home friday and the needle was off the chart, so i stopped and waited for it to cool. then I took it home, and it took way to long to even make it to 40mph, and wouldnt go over, and got way too hot way too fast. Could it be the timing chain? and if so, how much about would it run me to get that fixed?
Old 01-22-2006, 08:02 PM
CD Smalley CD Smalley is offline
Re: ASAP! timing?
Unlikely.
Is it overheating when moving or will it over heat at idle as well?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 01-22-2006, 08:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: ASAP! timing?
How is the economy? Sounds like a classic case of a plugged catalytic converter.
Old 01-22-2006, 08:15 PM
Re: ASAP! timing?
It just overheats when its running, but idling does get pretty hot. When its hot and driving, it knocks at around 35 too. I'm pretty sure thats a lifter hitting the valve cover. The economy is fine, and I'm pretty sure the cats ok. But supposing it isnt, would it cause all that that quick?
Old 01-22-2006, 08:50 PM
Re: ASAP! timing?
A plugged cat would cause quite a bit of overheating like that.
I assume you have checked the coolant level. Is the upper hose hot when this happens. Could be a stuck thermostat as well. If it is only overheating when driving, then look at a collapsing lower radiator hose.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 01-22-2006, 08:58 PM
Re: ASAP! timing?
thermostat had crossed my mind. I'll probably try that first and hope its that simple. Coolant levels are fine, and upper hose is hot.
Old 01-26-2006, 10:53 PM
TommySS TommySS is offline
Re: ASAP! timing?
Mine was a stuck t-stat.
Old 01-27-2006, 02:43 AM
UnexplodedCow UnexplodedCow is offline
Send a message via Yahoo to UnexplodedCow
Re: ASAP! timing?
sounds like a stuck thermostat to me, too. If it won't do over 40, though, even floored, then I'd say your cat is plugged.....happened to me so bad once the car wouldn't do 10...car got REALLY hot, too...wish I'd known more about them back then.
