Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 01-22-2006, 06:05 PM
jrhpah jrhpah is offline
Neutral Safety switch
I have a 69 chevelle that was converted from a Power glide on the column to a TH350 on the floor. The steering column was changed out as well to a floor shift steering column. I have owned the car a year and just recently discovered that the car could be started in reverse or drive, which lead me to the neutral safety switch. The switch is located on the steering column. Here is the problem. I did some research and came up with two different scenarios. One is that it's ok to have the column mounted switch since there is still linkage going from the transmission to the steering column with a floor shift and that "back linkage" will operate the neutral safety switch. The other scenario is that the neutral safety switch should be mounted to the horseshoe shifter with new wire harnesses. Anyone know which is correct?
Old 01-24-2006, 11:17 PM
CRUZN69's Avatar
CRUZN69 CRUZN69 is offline
Send a message via AIM to CRUZN69
Re: Neutral Safety switch
I went with the switch in the shifter. That's where it is when the car comes with a floor shifter. You can buy the complete kit from:
http://www.true-connections.com/
