Old 01-22-2006, 05:03 PM
cpolaris502's Avatar
cpolaris502 cpolaris502 is offline
Where did you run your amp wires?
I am trying to get my power cable from the battery into the car for my new amp. I cant find any ways to get through the firewall on the passenger side of the car. Where did you guys put yours through.
Old 01-22-2006, 05:10 PM
mas&NKS's Avatar
mas&NKS mas&NKS is offline
Re: Where did you run your amp wires?
I hate putting stuff throught the firewall, so i re-located my batter to the trunk. now i have a 6 inch wire running from my battery to the amp
Old 01-22-2006, 05:43 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
dont you still have to run a power cable thru the firwall to get to the battery? anyway under the ac hoses on the passenger side of the fire wall there will be a rubber cap in the fire wall. just get i flat head screwdriver and pop it out. thats what i did. let me know if you dont have a hole in yours. la
Old 01-22-2006, 05:44 PM
uiony uiony is offline
Send a message via AIM to uiony
Not sure how the hole got there but was there went i bought it. So I just put my wire through that hole.
'90 Honda Civic SI
Old 01-22-2006, 06:22 PM
thanks for the quick replies. I found that plug under the air cond. and managed to get them through there. thanks.
Old 01-23-2006, 03:35 AM
texwill texwill is offline
If you take the plug out make sure and wrap alot of tape or like I did stick a piece of rubber around the wire so it does not rub the firewall or you will arc it and the car will be toast.
Old 01-23-2006, 11:37 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
or just push a hole threw the plug and run the wire though that.
The Evil Sleeper
Old 01-23-2006, 02:49 PM
thanks, ill do that.
Old 01-23-2006, 09:40 PM
skotman's Avatar
skotman skotman is offline
good. i was gonna suggest that hole behind the A/C.
i had been toying with the idea of putting in an amp and subwoofer for a long time, but it wasn't until i found that hole through the firewall that was already there that i realized how easily i could run my wires. i ordered my amp and speaker that very day.
i've had some quirks with it though. the fuse box is just kinda hanging there in the engine bay. i haven't found anything to mount it to, but the terminal going from the battery to the amp is something ridiculous like 4 guage , so it supports its own weight fairly well.
i think the fuse that came with it is 80 amps.... and i'm pretty sure that my alternator only puts out 60 amps... so.... heh...
Old 01-23-2006, 09:44 PM
alphalanos alphalanos is offline
Thats what I did. It might as well have said "put amp wires here" to keep it clean just pop off ur door sill trim peices and stick it under there.
96 EJ6. Future home of boosted B18C1.
Old 01-23-2006, 11:52 PM
I tried putting a hole through the plug but after awhile the plug split and the wire was touching the firewall once again, alphalanos has a good point about the sill trim then just pop the back seat up off or the two hangers and run it through the back, it will look clean. I also mounted my amp over the back cover of the rear drivers side tail light, there is plenty of room to drill holes and still keep the trunk room, also it allows for a pretty big amp, I run two kenwood 1,000's over each tail light and just run the wires underneath the carpet. You cannot even see a wire except for about 1" that actually attaches the wires to the amps
Old 01-24-2006, 03:36 PM
Yup, i have all my wires run under the carpet and the door moldings so there is no signs that i have it in there.
