Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-22-2006, 04:45 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Turbo MAF, NT MAF
i see there is a difference between between the Turbo MAF and the N/A MAF. i am wondering if anyone knows if there is any difference between the air/fuel mixture reading between the 2 MAF's. Thank You
Chad
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 01-22-2006, 09:19 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: Turbo MAF, NT MAF
im not totaly possitive but im pritty sure the turbo's need more fuel
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 01-22-2006, 10:48 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
The maf doesn't calculate a/f ratio, it just measures the air coming in and sends it to the ecu which then calculates how much fuel to add. I wouldn't think they are interchangeable, I dont see any benefit in swapping them. If the plugs don't match it won't work. If you want a bette lowing maf go with the gm blow through and a maft.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-23-2006, 02:19 PM
sice im going to get a turbo ECU tonight, ill see how it runs with the turbo ECU cause i have a rought idle and sometimes it has a jump in rpms to like 4500 and there is no vac leaks that i know of. ill see how the turbo ecu helps out.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 01-25-2006, 05:20 PM
2of9 2of9 is offline
get the EPROM ecu!! isnt it not good to run the turbo ecu...with the NT ecu...??? okay....?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
