I have a 1993 dodge caravan with a 3.3l v6. 175,000 miles runs good but hard to start.It has to turn over for 5to7 sec before it will start.
Re: hard to start
Welcome to AF!!
Check the fuel pressure to see if it is within spec. This could be a bad regulator, dirty fuel filter or a fuel pump going bad. By checking the fuel pressure you should be more able to tell what is going on. If the pressure is low that will cause the van to be hard to start. |
Re: hard to start
Thank you, I replaced the fuel filter a year ago September. The regulator and fuel pump I replaced last month (ouch)$$$$. Also plugs,wires,pvc.I did'nt check the fuel pressure after i replaced the pump.I thought after i changed the fuel pump the hard starting would be fixed, but not yet.
