Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-22-2006, 03:59 PM
oh_snnnap! oh_snnnap! is offline
Need to find rear axle code
It's a 97 Jimmy with either McKinnon or Buffalo rear. There is supposed to be a tag or stamp on it, but I can find neither. Is there a visual difference? Or maybe another place I can find a build code?
Thanks,
Paul B
Old 01-22-2006, 06:01 PM
old_master's Avatar
Advisor/Moderator
Re: Need to find rear axle code
During the manufacturing process of the rear axle, there is a sheet metal tag attached to one of the cover bolts. The tag is approximately 5/8" wide and 3" long. It contains axle ratio, model, build date, etc. If the tag is missing, the RPO code can be found on a sticker attached to the glove box door. There is a thread in the Blazer forum that tells what each RPO code means. RPO codes on that sticker will tell every option on that particular vehicle. An RPO code is three characters in length.
Old 01-23-2006, 10:32 PM
Jimmy58's Avatar
Jimmy58 Jimmy58 is offline
your jimmy should also have the axle info stamped into the left axle tube on the front side.
Old 01-24-2006, 06:12 PM
JimmySLS's Avatar
JimmySLS JimmySLS is offline
I had trouble with this also on my Jimmy..Just out of curiosity what is wrong with your rear end?Good luck in finding the code..
2001 Bonneville SLE "Bella Donna"..... K&N Filter, Ceramics pads on front and rear,XM radio.. 130k on the clock...All the bells and whistles...check my car out at [url]www.cardomain.com/ride/2058777... R.I.P Bella Donna..wrecked on 05-08-07...
