Old 01-22-2006, 02:58 PM
SsHaDyGt SsHaDyGt is offline
Misfire #6 odd
I changed plugs and wires dec 04 and a couple months later I was getting a misfire in #6 i took out the plug and the end where the little metal cap screws on was bent. So i changed the plug and it worked fine. Now I am having the same problem misfire in #6 I havent taken the plug out yet. (im waiting for the engine to cool down) I was wondering what might cause this. The is the plug that is in front of the o2 sensor. Anyone eles see this before?
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 01-22-2006, 03:17 PM
maxwedge maxwedge is offline
A990 racer
Re: Misfire #6 odd
All I will say here is I hope these are not Bosch plugs, if so "chuck em!"
Old 01-22-2006, 03:55 PM
Re: Misfire #6 odd
The plugs are NGK TR6's I think that mabey I bent the plug last time when I was taking it out, beacause I snapped the plug in half this time. Last time replacing the plug seemed to help. I put the stock plug in for now. Any Idea why this could be happening?
Old 01-23-2006, 09:57 AM
A990 racer
Re: Misfire #6 odd
See if you have good spark to # 6, if so pull the plug and look at it, this is basic diagnostics.
Old 01-23-2006, 10:13 AM
ern2112 ern2112 is offline
Re: Misfire #6 odd
Man.....don't forget the ol injector....just had the same problem myself. Also.....you might consider moving your coil packs around see if the problem jumps to a new cylinder
Old 01-23-2006, 10:21 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Misfire #6 odd
If the plugs you are installing have the caps that unscrew, you need to tighten those caps so they can't vibrate loose. If you don't, you'll be chasing misfires from now until eternity. Plug 6 is in the rear, where the oxygen sensor is in the way when installing (if a GTP is like a GT). You need to be careful tightening that plug, or you can catch the tip and bend it so the wire doesn't make a good connection. I used a flex extension that will give you just enough clearance without flopping all around like u-joints do.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
