Heated mirrors
The other day I took my truck to the dealer and they said I had a bad oxygen sensor and a leaking right front axle seal. I had them change both and now my heated mirrors dont work. The rear window defogger still works. Any ideas would be helpful. 03 2500 hd
Re: Heated mirrors
Well, I can tell you that the dealer work has nothing to do with your mirrors not heating. It's not unusual for them to stop working, however to have both of them stop at the same time is odd. Call a local glass shop (small, independant shop preferably), and tell them you need both mirrors replaced. They will probably put in Burco's (brand name). Should be less than a hundred for both. You're positive they both stopped working? - Rob
Re: Heated mirrors
instead of replacing them right away, why not backtrack to solutions for why they might not be working?
is there a fuse or something for the mirror warmers, etc? |
Re: Heated mirrors
yes,both mirrors don't work. I called the dealer and they will hook it up to the scanner and check it out. The mirrors are controlled by the trucks computer. As far as I can tell by the factory manual there are no fuses just a relay,please correct me if I am wrong. Also the rear window defogger is on the same relay and it is still working.
Re: Heated mirrors
Found corroded terminals inside door where mirror plugs in.
Re: Heated mirrors
Glad it was something simple
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
Re: Heated mirrors
Glad to hear you solved your problem. And thanks for posting your solution.
I'm about to pull off my door panel. Neither one of my power mirrors tilts up. They will move side to side and down but not up. Now I will pay closer attention to the connections.
