Belt Replacement
I know this will sound silly, but what is the easiest method to replace the serpentine belt on a 2000 Silverado 1500, 5.3L.I don't see a tension idle pully like on the ac belt that would release the belt tension to remove it.
Re: Belt Replacement
The absolute easiest way is to take it in and have someone else do it.
**2007 Avalanche LT. ** ![]() 6" Pro Comp lift 305/55/20 BFG A/T KO'S K&N FIPK GENII Flo Pro V force muffler & 4" slash cut stainless tips Color matched front and rear Bowties 3" polished stainless bull bar and Nerf bars |
oosp wrong belt.
just unwind it then rewinded the new one. there is realy no easy way. the one blelt system is a bear to put on. if you do it a few times it becomes real easy to do. |
It can't be too hard. Just take your time and read the little schematic on the plastic shield under the hood that tells you how to run it. I used to do this all the time at the service station.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
