Old 01-22-2006, 10:19 AM
chackbay chackbay is offline
Manifold Noise 2000 Silverado
My 2000 Silverado has tapping/clicking sound only when accelerating (mostly from the driver side). The dealer ship told me that this was not injectors but a manifold design issue which all 5.3L have. Something about the way the gas comes out of the manifold.
Has any one else heard or been told the same? This started approx. 1 year after I purchased the truck.
Old 01-22-2006, 09:01 PM
98vert6spd 98vert6spd is offline
Re: Manifold Noise 2000 Silverado
i hear a ticking in my 4.8 as well under acceleration
always makes me feal like i have a worn out engine
but its sooo faint i cant even hear it unless i listen real closely
im curious what it is too
i have 116k on mine so it could be nearly worn out
Old 01-22-2006, 09:06 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
4.8 with 116,000 No, has alot of life left on it. Just keep it up on basic stuff.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-23-2006, 05:42 AM
I got 101K on this truck and hopefully its not worn out. This noise started approx. 1 year after I purchased it back in 2000. I haen't heard of too many folks who has heard this noise.
Old 01-23-2006, 02:25 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
I'm not sure if this is what you are hearing, but take a look at the rear exhaust manifold bolt on the driver's side. GM V8's are notorious for breaking the rear bolt off during expansion and contraction. (service bulletins) My 5.7 did it, my 6.0 did it, and I've seen plenty of 5.3's that have done it. In the early stages, the leak seals up after a short warmup, but many times the broken bolt will allow the rear exhaust runner to crack. Then the ticking does not go away.
'02 2500HD 6.0/4.10 Air Lift bags, 175 psi onboard air
Old 01-23-2006, 05:54 PM
do you know what service bulletin?
Thanks
Old 01-23-2006, 07:44 PM
06Z71 06Z71 is offline
In my 99 6.0 I had 6 bolts break in the exhaust manifold 4 on the driver side and 2 on the passenger side so I used a little JB weld on it and patched up the hole worked fine. I had 162000 miles on it when it happened and I just traded it in for $7500 with 167000 and it only been in the shop for a fuel pump at 160000 miles. NOTHING LIKE A CHEVY!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-24-2006, 07:31 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
You know, I have this same sound. It sounds like I have an exhaust leak, but so far I haven't found one. I haven't been told anything about it but I do know what your talking about.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-24-2006, 08:19 AM
Mine started breaking with the last bolt closes to the firewall on the driver side you might want to start looking there.
Old 01-24-2006, 08:29 AM
jeverett's Avatar
I do know I have a bolt broken off under the truck where the pipe and manifold meet. I haven't looked where the manifold and head meet.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-24-2006, 05:01 PM
masapell's Avatar
masapell masapell is offline
Thanks
I'd be interested to know this too. I just found a broken one on the driver's side, front bolt. I'm sure it is a costly job to fix too?
2014 Ram 1500 Crew Cab
Old 01-24-2006, 08:55 PM
The bad thing is that when you try to take the exhaust off you will break all the rest of the bolts off then you have to take the head off and drill all the bolts out. Patch it up and sell it that what I did let it be someone else headache
Old 01-25-2006, 07:30 AM
jeverett's Avatar
Maybe I'lll just get some headers
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
