Old 01-22-2006, 09:39 AM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Oil leak, help please!!!
hi guys..
l got my car from mechanic yesterday. and l asked him if he saw any other problem, and he told me that l had an oil leak. it wasnt dripping he said, it w wet under the engine he said.
do l have to fix oil leak immediately or it is not a big deal as long as l keep my oil level normal?
my mechanic told me that l got v8 and there is not much room to work and thats why v8 engine has more labor. becuse it is hard to work on them. and he said, it would be expensive to fix it.
l really do not wanna spend money on it anymore, if u guys have any easy ideas, that would be great.
thank you.
Erdal
Old 01-22-2006, 10:15 AM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Oil leak, help please!!!
Where is the leak coming from??
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 01-22-2006, 11:55 AM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
hey man, sorry to hear about the leak. I would say check your level regularly. You should be fine with that. Definately put some dye in the oil, use one of those cool lights you get in the dye kit, and bam you see right where the oil is coming from, going, and blah blah. But anyway as long as you do'nt ahve puddles under there everyday, just check your level and maintain it, and you should be fine. Good luck!
Jake
Old 01-22-2006, 12:23 PM
doodad's Avatar
l called the mechanic and l asked him..
he said that the oil is leaking from the front of the engine from the distributor.
l hope it is not serious problem..
thank you.
Old 01-22-2006, 12:31 PM
Mr. Luos's Avatar
Firebird Guy
Opti-spark?
Stock'ish'
Old 01-22-2006, 01:25 PM
doodad's Avatar
Opti-spark?
l have no idea what is that mean man. l am sorry. all l know is that oil is leaking from the front of the engine, distributor.
if u can tell me something with this info, that would be appriciated.
thank you.
Old 01-22-2006, 02:43 PM
Mr. Luos's Avatar
Firebird Guy
I am not 100% on this...but isn't the Opti-spark the GM name for the distributor??
They are problematic on LT1 cars for sure.
Stock'ish'
Old 01-22-2006, 02:47 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Mr. Luos, "The King"!!
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-22-2006, 06:39 PM
doodad's Avatar
but is that a serious problem? do l have to fix it right away?
Old 01-23-2006, 12:50 AM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
the opti spark is the LT1 version of a distributer. Mostly failing due to getting wet too often....like if your water pump goes, pisses all over your opti spark...chances are your opti-crap is next. I never heard of them being a problem with oil leaks...but there is other gaskets in that area too sooo....who knows. The dye kit is the only way to really know.
If u need a new opti spark they are pricey...but i found a barely used one out of a wrecked vette for cheap. i'll let it go for 100 bucks if u need it. only works on 92-94 LT1's tho...the non vented. I forget what year the vented ones game out may have been 95 or 96.
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 01-23-2006, 12:52 AM
nevermind, i just read your sig...97 LT1s deffinatly came with vented opti sparks...so mine won't work for you.
Old 01-23-2006, 03:14 PM
doodad's Avatar
oh.. ok man.
thank you..
Old 01-23-2006, 06:16 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Your timing cover is probably leaking down by the pan seal. Thats a commen leak point whenever the timing cover has been taken off. The opti is right infront of that and thats why he is saying its the opti.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
