Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-22-2006, 12:40 AM
studious03 studious03 is offline
1992 No Start
Its been about 2 wks since i last drove it, and then i noticed when goin uphill it would seem to slip in between gears. Now today when i tried to start her up she wouldn't turn over. Recently put in New spark plugs, new rotor, new cap. Has half a tank of fuel. Has fuel coming through but still doesn't turn over. Even tried a can of starter fluid and still nothin just cranks and wont turn. Thinking of putting in a new Ignition module.... Really in need of some advice.....
1993 Toyota Camry LE 2.2
1992 Chevrolet Caprice 5.0
1995 Jeep Grand Cherokee Limited 5.2
Old 01-22-2006, 02:39 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: 1992 No Start
if it wont turn over at all, check you starter
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 01-22-2006, 11:03 AM
Re: 1992 No Start
Yes i will check my starter today as well as a new ignition module, she wants to start sooo bad and even with the starter fluid it seemed so close. and there is spark i'm just not sure how much of a spark i need....
Old 01-22-2006, 11:21 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1992 No Start
"Doesn't turn over" means doesn't crank, i.e. dead battery, siezed engine. If it cranks but doesn't start, it's "turning over".
So, does it crank? Do the pulleys turn when you hit the starter? Or does it go "clack" when you turn the key?
If you checked the spark and it's a bright bluish-white color, then it's hot enough to run the engine. My guess is either mechanical (i.e. bad timing chain) or fuel delivery. If the cranking sounds wierd and unnatural, take the cap off of the distributor and have a buddy turn the key. If the pulleys on the front turn, but the distributor rotor does not, you have a bad timing chain/sprocket.
Old 01-22-2006, 12:50 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1992 No Start
Also go easy on that starting fluid. Or you may blow it sky high.
The only safe starting fluid is carb cleaner in small amounts.
Good spark is good hot blue spark at the plugs that will jump over a 1/4 in up to a 1/2 or more and will jolt your teeth when you hang on the plug wire.
MT
MT
Old 01-22-2006, 05:01 PM
Re: 1992 No Start
Turns out timing was a little off, all i need now is the distributor firing order... It runs but will cut off i think the fire order is slightly off.... if any has the specs on the ditributor firing order i'd gladly appreciate it.....
Old 01-22-2006, 05:10 PM
MT-2500's Avatar
AF - Advisor
Re: 1992 No Start
Chev V8 is 1 8 4 3 6 5 7 2 clock wise.
Did you base time it with spark advance disabled or just turn the dist?
MT
MT
Old 01-22-2006, 09:49 PM
Re: 1992 No Start
Yea i just turned the distributor. Does anyone have a diagram of the distributor. if not then i have to buy a book....
Old 01-22-2006, 10:13 PM
MT-2500's Avatar
AF - Advisor
Re: 1992 No Start
If you need repair info/ book.
Here is a link to all data DIY repair info sub.online 24.95$ and 10 minutes and you are set up and ready to go.
http://www.alldata.com/products/diy/index.html
MT
MT
Old 01-24-2006, 12:33 AM
Re: 1992 No Start
Thank you everyone once again you have helped me! just "based timed it" until i got it right... She's running again!
