Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 01-21-2006, 11:02 PM
TODD17406 TODD17406 is offline
98 CRV err-03 on radio/CD player
Greetings folks,
Battery died recently with a disk in CD player. After jumping the battery, the radio displays the err-03 which means CD eject not functioning. Any experience with this out there? How to clear this error? How to remove CD disk or how to remove radio/CD player? Hoping I don't have to take to dealer.
Old 01-23-2006, 06:27 PM
lorunner lorunner is offline
Re: 98 CRV err-03 on radio/CD player
All this happened after you put in the radio code succesfully?
Stop asking me about radio codes I cant get them anymore!!!
Old 03-04-2007, 12:42 AM
deannn deannn is offline
i had the exact same problem today. i dont know how to fix it either
Old 09-15-2007, 04:41 PM
pazzionatephoenix pazzionatephoenix is offline
Hey ummm I just went through that problem I hope I'm not 2 late well behind the radio the is a serial # get that and it will also help to have the vin # just call up honda and request the code... there needs 2 be a 6 # code
Good luck
Old 09-26-2007, 08:14 PM
njtaf2007 njtaf2007 is offline
Unhappy Re: 98 CRV err-03 on radio/CD player
This site is cool. Thanks for all your assistance.I have the same issue and actually have the code.
Here's what I did:
1) 1+6 and turn(pushed) the radion button
2) set of number came up 17125160
3) released 1+6
4) entered/pressed the 5 digit code
5) waited.......then the ERROR E code came back
I'm I missing something on the steps or is there something else with this ERROR E?
Appreciate any assistance.
njt
Old 09-26-2007, 09:04 PM
Here's what I did:
3) released 1+6
njt
SOON AFTER I POSTED THIS I FOUND MY ANSWER from another AF member. With the ERROR E message I needed to reset the radio by removing the BACK-UP fuse from under the hood for 10 secs....then back to step 1 above.....now it's unlocked......THANKS FOR ALL THE HELP!!!
Old 09-26-2007, 10:23 PM
jgr7 jgr7 is offline
Here is another tip if you have to change the battery or disconnect it for maintenance. If you have not lost the radio power you can use one of those portable battery jumper boxes that has the plug that goes into the cigarette lighter or power outlet. This will keep your radio presets and not make you have to get the lock code. I just changed my battery this last weekend and it worked great.
Jeff
