Old 01-21-2006, 09:21 PM
stevieracer49 stevieracer49 is offline
Help No Start
I've been rackin my brain out on this one, 94 Buick lesabre 3800, if I spray starting fluid in the car will fire up then it shuts down like somebody turned the key off scanned it out got code PO341 camshaft position sensor
so I replaced that I took the ignition module off and took it to auto zone and tested out fine. the fuel pressure is right in spec. with the scanner I read the rpm's at 200-225. I read in the postings here that if you can read the rpm's the crank sensor is fine. I am kind of stumped, any help would be appreciated Thanx Steve, excuse the grammer please
P.S. I changed the plugs and wires 2 weeks before the problems started....i also replaced all the vacuam hoses
Old 01-21-2006, 10:04 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Help No Start
Well, it sounds as if you have spark and fuel pressure, so your next step would be to use a noid light to test the injectors and see if they are pulsing.
Old 01-22-2006, 01:12 AM
Re: Help No Start
thats what I figured I'll have to run and get some at harbour freight Thx
Old 01-23-2006, 10:43 AM
Re: Help No Start
have to make my own harbour freight was out ...Just my luck.
Thx Steve
Old 01-27-2006, 04:51 PM
Talking Re: Help No Start
Well, got it fixed after the noid lite test of course the car fired right up the lite was flashing along,then just like if you turned the key off it died lite quit flashing. I decided to check the RPM's again while I was crankin I didn't have any reading I figured that the only sensor that would give me a rpm reading would be the crankshaft sensor so I replaced it car fired up..How would a person check this out with out a scanning tool? could get expensive just replacing sensors or control modules...thx for all the help Steve
Old 02-08-2006, 10:44 PM
kram5527 kram5527 is offline
Re: Help No Start
Usually an oscilloscope will help with troubleshootig sensors, they show the waveform that the sensor is producing (both frequency and amplitude). I use a velleman HPS10 oscilloscope (use your favorite search engine and it lists on ebay for ~$125) not bad if you do work with electronics or sensors. By the way, it also functions well as a voltmeter.
Hope this is helpful
Old 02-10-2006, 01:23 PM
Bassasasin Bassasasin is offline
Re: Help No Start
Interesting.. I Banged out a CRANKshaft sensor problem.. too..(took months). Now its happy..I swapped everything I could reach.. IgModule, Comuter, Camshaft sensor, Bugged out the wiring. Phantom Indicators were wild.. Spedometer swings.. dash lights.. Bucking at high speed, Phantom stalling.. but CAMshaft sensor was the only error. I finally had to take it to a shop and say JUST CHANGE THE CRANKSHAFT SENSOR. .($100) Vualah.. or is that WALAH!! problem solved.
Old 02-11-2006, 05:41 PM
BillD BillD is offline
Re: Help No Start
Any check engine light? My car did what I call "flash" stalling. In other words the red idiot lights by the gauges would flash and the engine would die for a second and then it would run again. The computer stored cam, crank, and spark timing sensor faults. Turned out to be the ECM itself that was bad. Swapped a used one in from Ebay and runs great now.
BD
