Old 01-21-2006, 08:21 PM
And1fixer And1fixer is offline
Angry idle
Ahhh, my idle is rough after putting seafoam, cleaning the IAC, (it was really dirty when i took it out), changing wires and plugs, and changing the top motor mount and the transaxle mount....what else can i do to fix it?
Old 01-24-2006, 05:03 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
Re: idle
hows your coil packs?
Old 01-25-2006, 12:29 AM
RahX RahX is offline
Re: idle
wait, is it STILL rough or did it get rough after you did that? how did you put the seafoam in, through the gastank or in the intake? also when you cleaned the iac did you spray cleaner into the intake? sometimes it takes awhile for that stuff to work its way out.
Old 01-25-2006, 06:34 AM
Re: idle
well, i never checked the coil packs...and it was still rough after i did the seafoam...i put the seafoam through the gas tank and the PVC.yeah, i sprayed some in the opening of the IAC...but the coil packs could cause the rough idle?
