Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-21-2006, 07:57 PM
hansonboy6330 hansonboy6330 is offline
Car Overheats
When cruising on freeway, the temp needle remains at halfway point...
At city speed, when i let go of the gas pedal, or when going uphill, the needle starts moving up...
The backup fan (really loud one), comes on when the needle reaches 3/4 point...
This problem began to happen lately...
Again, my car needs 60k tune-up...
My radiator does leak, but once in a while? Sometimes, I can see the coolant just seeping out somewhere, but most of the time, it's dry... I think its really slight problem, cause my coolant level is still pretty high...
The guy at autozone says I should try a coolant flush, since there might be dirt inside...
I am just confused... Any ideas?
Old 01-22-2006, 06:12 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Car Overheats
Thermostat might be stuck
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 01-22-2006, 12:26 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Car Overheats
Whats the outside temp. like? My car gets really hot in the summer...like up to the 3/4 point when I am in traffic. But it goes back down when I start driving. I think it's just because there isnt a lot of ventilation in there...so long as it goes back down I wouldnt be worried about it. I would still get it flushed, but I wouldnt expect it to fix anything...just piece of mind.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-22-2006, 02:34 PM
808drifter 808drifter is offline
Re: Car Overheats
just flush it your self i just did
Old 01-22-2006, 03:14 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Car Overheats
do you see crusty antifreeze coming from the top hose? my car's connection to the radiator at the top hose wasn't 100% and they said it was a really common problem with these cars. flush it first, get the tuneup and then see where you stand, it may be as simple as that upper radiator hose
Don't act like you don't love it.
503/2000
Old 01-22-2006, 03:44 PM
Re: Car Overheats
or just low coolnt level and when u refill burp the system.
Old 01-22-2006, 08:07 PM
Re: Car Overheats
Outside temperature is really cold... It's Bay Area cold... I took it down to LA last Nov (definitely hotter than current situation), and nothing wrong with it...
Yea, I think I see some crusty stuff on the top hose... How do you fix that?
Coolant level is okay... I checked it when it's cold/hot and its at an acceptable level...
Is it easy to flush?
Old 01-23-2006, 12:14 AM
Sleepr awd's Avatar
Re: Car Overheats
if you can get the dealership to fix it under warranty, if not buy an aftermarket hose from RRE or the dealership will have modified ones, a new clamp, clean it off and fix it, really tight!!! shouldn't be too hard to replace urself, but if the dealership does it free, go for that
make sure your car has been off for like 4+ hours if you decide to do it yourselfthough, it seems to carry heat for a while
i noticed antifreeze under my car at less than 10k miles, so of couse i took it to the dealership afraid i blew the head... it never got bad enough to overheat though
503/2000
Old 01-23-2006, 02:23 PM
Re: Car Overheats
heres how u flush it
1. Make sure car is cooled down.
2. Remove radiator hoses.
3. Run water through radiator from top to flush that.
4. run water through block frm top hole.
5. reconect hoses (i would replace factory spring clamps for worm drives, the ones you screw down) tightn everything down.
6. Refill radiator till coolent is at top of radiator.
7. Run can with heater on high and add more coolent when level in radiator drops, (repeat till it starts to over flow and not drop anymore, this should take between 15/30 min to do.)
8. replace the cap and make sure resevor is full.
Thats about it. Just remember to use a 50/50 mix even if it dont get cold where you live cause it also raises the boiling piont of the water.
Old 01-31-2006, 05:40 PM
dmk720 dmk720 is offline
Re: Car Overheats
How come when my 2000 eclipse gt overheated and the coolant was low in the radiator, reservoir level was always good and it did not adjust the level of coolant in the radiator?
Old 01-31-2006, 06:36 PM
Re: Car Overheats
resevor is so that it dont overflow
otherwise it dont work in our cars
Old 02-05-2006, 06:25 PM
Re: Car Overheats
Okay, so I took my car to a mechanic for my 60,000 maintenance service (which includes a coolant flush)... I told him about my overheating problem, and he says he'll do a pressure test...
Found out that my radiator was leaking... He says our type of radiator leaks easily because of how its designed... And even if the reservoir says the level is good, it is not a good indication that it's okay. Since the cooling system relies on pressure to pull the coolant from reservoir, if theres a leak in the radiator, the system would not work...
The best way to check is by unscrewing the radiator cap and take a look... Only do this after the engine is turned off for around 15 minutes, and open slowly (treat it like a bottle of soda).
Old 02-06-2006, 04:18 PM
Sleepr awd's Avatar
Re: Car Overheats
that is an interesting conclusion! i'll start saving for a fluidyne
503/2000
