Old 01-21-2006, 05:43 PM
jboler jboler is offline
Roaring noise on the front end
My van is making a large roaring noise when you drive it. I first suspected brake pads, but replacing them did not help. Any ideas?
Old 01-21-2006, 06:46 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Roaring noise on the front end
Hello
We need more information to help you out. What year? How long have you owned the van?
I take it the noise is only when the van is moving because you thought it was the brake pads. I'm I correct?
Does the noies get louder the faster you go? Does it change when you turn the steering wheel? I'm thinking you may have a bad wheel bearing.
Post back with what you can answer and we'll try to help you out.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 01-21-2006, 07:15 PM
wiswind wiswind is offline
If it is a wheel bearing....they are press fitted......
Requires special tooling to remove.
Some have taken the hub off...and taken it to a dealership / shop to have them change....
Or....can take it in to have done.
This is based upon what I have read on this forum....."knock on wood" have not been down that road with my windstar.
Old 01-22-2006, 08:22 AM
Originally Posted by LeSabre97mint
Hello
Regards
Dan
It's a 99 Model Windstar. The noise only occurs when the van is in motion. There is no noticeable noise difference when turning.
If it is the bearing, which I suspect it is, is this going to be a bolt on assembly, or a "press on?"
Thanks,
Old 01-22-2006, 11:07 PM
yotermanic yotermanic is offline
The good news is that this bearing is a bolt on part. The bad news is that makes it very expensive as the only way you can get it is with the housing, hub and ABS sensor. The other good news is that they are the same side to side so if you guess the wrong side, you can switch it and put the original back on the other side. Anyhow, good luck with it!
