Old 01-21-2006, 04:35 PM
ADSHAW ADSHAW is offline
Any Ideas
I Have A 1998 Ford Taurus Se It Has A 24 Valve Dohc Engine And Periodically Right After You Start It Up And Drive Maybe 1 Minute The Car Loses Power Steering And The Radio I Am Not Sure What To Check For
Old 01-21-2006, 04:55 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Any Ideas
The variable assist ps VAPS is electronic controled by the gem module.
I would check all fuse and power feeds and charging system.
The loose of raido and PS at same time points to a 12 volt power feed problem.
Also check for any stored codes in body/gem/eng computers.
Will it do the same thing if you let it warm up before driving?
MT
MT
Old 01-21-2006, 05:24 PM
Re: Any Ideas
ONCE IT WARMS UP I HAVE NOT HAD ANY PROBLEMS OUT OF IT
Old 01-21-2006, 05:45 PM
MT-2500's Avatar
AF - Advisor
Re: Any Ideas
Look over the power feeds and charging system and also the belts on it.
If you do not find anything it might a good job for the dealer to check out.
Good luck and let us know how it goes.
MT
MT
Old 01-21-2006, 06:06 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Any Ideas
Check the transmission range sensor on top of the transaxle. It is the piece that has a wiring connector of about 10 wires in it. It bolts to the transaxle under the linkage. It can be seen by looking just to the inside of the brake master cylinder. Part is under 50$. What makes me think the TR sensor is the radio and power steering going out at the same time. Good luck. We have run into about 50 of these in our fleet.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-01-2006, 03:58 PM
Re: Any Ideas
I REPLACED THE SENSOR AND IT STILL DOES IT SO I AM GOING TO MAKE AN APPOINTMENT WITH THE DEALER THANKS FOR YOUR HELP
Old 02-01-2006, 03:59 PM
Re: Any Ideas
MT
I HAVE CHECKED EVERYTHING THAT I KNOW OF SO I AM MAKING AN APPOINTMENT FOR THE DEALER THANKS FOR YOUR HELP
Old 02-18-2006, 09:25 PM
Re: Any Ideas
MT
I TOOK THE CAR TO THE DEALER HE HOOKED IT UP TP THE COMPUTER FOUND A CODE THAT WAS STORED IN THERE HE CLEARED IT OUT HE KEPT IT FOR A WEEK AND DROVE IT OCCASIONLY AND HAVE NOT HAD ANY PROBLEMS SINCE THANK YOU
Old 02-18-2006, 09:26 PM
Re: Any Ideas
I TOOK IT TO THE DEALER HE HOOKED THE COMPUTER UP TO IT IT HAD A CODE STORED IN IT HE CLEARED IT OUT AND IT HAS BEEN FINE SINCE THANK YOU
Old 02-19-2006, 11:32 AM
brokenantimatter brokenantimatter is offline
Re: Any Ideas
THANK YOU FOR TYPING IN ALL CAPS........................-_-;
Two questions?
Did they give you the error code and are you using a third party stereo?
Old 02-19-2006, 02:37 PM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: Any Ideas
I've *never* known an after market stereo to throw any sort of trouble code in my 9 years of installations. Though...there's always a first time for everything. :P
I reject your reality, and substitute it with my own.
Old 02-19-2006, 06:03 PM
Re: Any Ideas
It wasn't the Stereo it was a wire coming loose from the poorly crimped harness.
Old 02-19-2006, 10:04 PM
Re: Any Ideas
Two questions?
No they did not give me the code the stereo is factory
Old 02-20-2006, 12:24 AM
Re: Any Ideas
I guess I should have specified a "properly installed" stereo.
