Old 06-16-2002, 03:21 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Breakin in question!!
Hey sup. My swap is almost complete! Before i drive it do i have to break it in before i punch it? Thanks.
Old 06-16-2002, 10:43 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
if you replaced the clutch you should wait a while before getting on it. otherwise you will be buying a new clutch again
Old 06-17-2002, 01:24 AM
CRX586's Avatar
CRX586 CRX586 is offline
I just had my B16A swap completed. I'm not supposed to rev past 4000 rpm for the first 800 miles, at which point we change the oil.
02 Lexus IS300
Old 06-17-2002, 02:33 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Well unless you striped the engine down and rebuilt it before you installed it then I see no reason why you should have to run in the engine.
After all its a 2nd hand engine remember, and its already been well and truley thrashed in Japan.
When I got my car (which is from Japan just like your engine) I did take it easy for a week or two, but that mostly me getting used to an engine that wanted to rev to 8,000 (when my old car with similar HP couldn't make it past 6,500) and being cautious about braking something, or finding something wrong with it.
But as long as you put freash oil and new filter in it, and give it a few miles to make sure it all works as it should, I see no reason why you shouldn't just floor it.
Old 06-17-2002, 10:08 AM
mellowboy's Avatar
Ok kool thanks guys.
Old 06-17-2002, 01:45 PM
StageOneGalant's Avatar
StageOneGalant StageOneGalant is offline
Send a message via AIM to StageOneGalant
Talking yep i would say so
yea.. i would say so,, atleast for the first 1000 miles or the first month depending on how much u drive... atleast thats what i was told and did to my car.. when i got my engine work done.. i spent too much money to jus go and destroy my egine right away... so jus be patient.. and break it in gradually..
95 Mitsubishi Galant
Stage 3 FrankinStein Turbo, RalliArt Headers/Clutch , Custom Kat back exhaust system...etc....(enuff info )
Euribuni Body Kit, 18 in Konig Wildcards.
"Just Because words are free, doesn't mean u can use them Freely."
Winning isn't everything, it's the ONLY thing!!
Old 06-17-2002, 06:26 PM
mellowboy's Avatar
Re: yep i would say so
Well i know for a new car u have to break it in for 1000 miles. I'm not so sure about my engine which supposedly it has 30,000-40,000 miles on it.
Old 06-18-2002, 02:16 AM
Moppie's Avatar
Master Connector
Re: Re: yep i would say so
Originally posted by mellowboy
..................... about my engine which supposedly it has 30,000-40,000 miles on it.
Exactly! its already been run in in Japan.
All you need to do is drive it gently for the first few miles to make sure you did the swap properly, and that nothing in the engine is badly worn or broken. (since its possible the reason the car it was in was scrapped is the engine was going out)
