Old 01-21-2006, 02:41 PM
98bluefirebird 98bluefirebird is offline
Send a message via AIM to 98bluefirebird
Supercharger?
What is the easiest way to supercharger a 3.8L v6 bird? I just picked up a 98 firebird and wanted to know the easiest way to supercharge my firebird.
Old 01-21-2006, 07:39 PM
Darrensls1 Darrensls1 is offline
Re: Supercharger?
I'm no expert on superchargers but I do know they are not cheap or easy. I found someone who asked a similair question on camaroz28 and this was the response:
Originally Posted by 2002 3.8
there is a supercharger for our cars, its called a powerdyne. you can get them at lmperformance.com. and costs $3,800. but you can get the better performacne gains from a 85 or 100 shot. you should consider NOS because you said you are rebuilding your engine and you are putting in diffrent internals.
It'll cost you a lot of money to get this thing going. I would consider just doing the basic bolt-ons (intake, exhaust) and then a 50-75 shot of N20 on top of that. Good luck with whatever you decide to do and grats on the ride.
1999 Pontiac Firebird Formula 100% bone stock. No really it is
Old 01-21-2006, 09:01 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Supercharger?
And....
Do not fall for the cheap things on EGAy.
If it isn't at least $3500...it isn't a real supercharger.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 01-21-2006, 09:44 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Supercharger?
ya like the electric blowers they call superchargers, lol, garentee 50hp my ass, lol.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-22-2006, 11:26 AM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Supercharger?
Why not go Turbo? Look at the GNs/etc...they're all 3.8+turbo.
If you want a supercharger, I'd look at vortech/prochargers site to see what they offer and if you don't find one there, call them and ask. Worst case they can say is we don't offer one. I had a P1SC on my 98 LS1 and it was great..I'm sure you could use a P1SC with a 4.1" pulley(3# for me..probably around 5-6 for you) and go from there. Just FYI
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 01-22-2006, 01:29 PM
Re: Supercharger?
Do you know if you can put a gm supercharger on a firebird or do you have to go aftermarket? Also, do you know a good site to find turbos for firebirds? Thanks
Old 01-22-2006, 01:34 PM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
Re: Supercharger?
There are things to be considered with supercharging. The first would be the compression ratio of a stock 3.8. If you spend near 4,000 dollars on a super charger and can only run a few pounds of boost, you may as well have bought a used lt1, paid someone to drop it in, and you'll have way better benefits, with way more power than even a well boosted 3.8(providing the 3.8 has no other mods) as far as nitrous, plesae please consult a professional and see what the stock 3.8 can handle without causing a problem, it's for the sake of driving it after you put a shot to it. But no matter what you do, good luck and keep us posted!
Jake
Old 01-22-2006, 03:57 PM
DarkblueTA's Avatar
Re: Supercharger?
Jake
Don't bother with a GM blower. Its a different setup on the GTP's etc from my understanding and you would have to put the new heads/etc on.
As far as compression ratio...its not any higher then an LS1 and if you were around earlier this year, you would have known I ran 8# on stock compression using the twin intercoolers that came in the kit by ATI.
LT1 would be a good option, but remember. You need new everything. Computer, wiring harness, front shocks and possible springs, and then any other supporting parts with the possibility of a new tranny. The 5 speed v6 tranny isn't going to hold with the LT1s power. Alot more to it then just throwing the engine in.
Nitrous, yes, he could do that. I would go wet shot with a window switch and Wide Open Throttle(WOT) switch.
Problem with the V6's in the fbodies is that when it comes to increasing power, its not really worth doing just bolt ons unless you do something major(turbo/blower/nitrous). In all seriousness, no matter what the young man does/decides to do, he needs to read and research what would be the best thing to achieve his power wants/needs and his spending $$$. That's just my
DarkblueTA
Old 01-22-2006, 04:04 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Re: Supercharger?
guys..
lets says l got 280a hp. on my car now, if l would add a supercharger or turbo charger, how many horsepower would l gain?
thank you.
Old 01-22-2006, 04:49 PM
97cavalier's Avatar
Re: Supercharger?
depends on how big it is and if you get a turbo or supercharger, and how much boost or psi you run.
Old 01-22-2006, 05:21 PM
DarkblueTA's Avatar
Re: Supercharger?
Originally Posted by doodad
guys..
thank you.
depends on the following.
1. size of the blower/turbo
2. intercooled or not
3. alky(or methane)/water injection
4. type of fuel used
5. timing in the programming(read: tune)
6. type of fuel system setup you run.
7. how many pounds of boost you're going to run
All of that goes into account. also, depends on your engine.
DarkblueTA
Old 01-22-2006, 05:36 PM
doodad's Avatar
Re: Supercharger?
man,
l got 97 formula LT1.
just a regular supercharger.. (not intercooled)
cant l just use supercharger?
do l have to have boost?
l always wondered, how much hp would l gain if l would have super/turbocharger.
Old 01-22-2006, 07:10 PM
BlackWS6BIRD BlackWS6BIRD is offline
Re: Supercharger?
Would you have to do anything other than bolt on a supercharger if you want to put one on a LS1. would any of the internals need to be changed as well?
Old 01-22-2006, 07:55 PM
Re: Supercharger?
Thanks for the information and all the tips! This is my first modern type car, i had two chevelles before i got the firebird. I'll have to start researching the options i have and what is needed with the options. Thanks for the help...AJ
