Old 01-21-2006, 02:13 PM
bigwally9876's Avatar
bigwally9876 bigwally9876 is offline
Send a message via Yahoo to bigwally9876
D16Z6 In to 92 Cx Hatch
i have a 92 cx hatch, that i wanna drop a d16z6 into it. I've done searches but not really found much info on the wiring.
So my question is what do i do about the wiring? i know i need a p28 ecu for the z6 but how the hel do i wire it and the vtec....Such a noob question i know but i am trying to do it my self.
Can i use the cx harness?
Old 01-21-2006, 09:22 PM
XhaloZ's Avatar
XhaloZ XhaloZ is offline
Send a message via MSN to XhaloZ
Re: D16Z6 In to 92 Cx Hatch
First off why a D16Z6? Second off you need to ground your motor and wire your vtec solenoid (comes with motor) to the p28 ecu since your hatch doesn't include that wire in the stock harness and then you should be set to go my friend. And you should be able to do it with the CX Harness... I would go to the engine swap forums and check to see if you gotta cross any wires or anything.
There are two types of people in this world, those who seperate people into two types and those who don't
Old 01-21-2006, 10:40 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Your shock tower harness (the section from the shock tower thru the firewall to the ECU) is already prewired for vtec. For some reason Honda decided to do with with all '92 models, even for the ones who don't have a vtec engine (like your CX). So all you have to do is match up the wires from the engine to the correct ones already at the shock tower plug. Here's a pic of where the wires meet: http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg
Old 01-22-2006, 12:37 AM
so according to this all i have to do is use the d16z6 engine harness and plug it into the existing firewall plug....Correct.
then i just have to mess with the o2 sensor and the knock sensor.....<----Still dont understand this too clear though.just wanna make sure cause i'll be doing this all my self
Old 01-22-2006, 10:30 AM
CivicSpoon's Avatar
There is no Spoon
Sorry I forgot the O2 wiring, but there is no knock sensor. Here's how to convert from the stock 1-wire O2 to a regular 4-wire O2 (which you'll need to buy): http://www.hybridautomotive.com/tech/o2/#one
