Old 01-21-2006, 02:00 PM
JimofWare JimofWare is offline
side to side play in front wheel???
Hi, here is what I got...
When I jack the car up with the weight off the front wheel I have a good inch or two on play if I push on the fron of the tire inwards. When I releace it it returns back. I check the tie rod and the play is not there. It is moving the half shaft and the play seems to be in the joint closest to the trans. the ball joint also moves but the wheel has no up and down play...
I am thinking CV joint maybe. but I get to clicking when turning. the only time I notice the problem is when I start off under hard acceleration when I push in the clutch to shift to second it turns it self to the right...
help me please
Jim
Old 01-21-2006, 06:24 PM
RahX RahX is offline
Re: side to side play in front wheel???
torque steer will move the steering wheel for you. if its LOOSE play, movement that SHOULDNT be there then i would be worried. a cv will pop and if its OLD it MIGHT cause a pull due to the joint not changing speed as well as it should. anyway if the tie rod is tight make sure its not a wheel bearing. also the ball joint shouldnt move when you pull/push the top and teh bottom of the tire.
Old 01-21-2006, 08:51 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Sounds like it could be a shot wheel bearing. Any growling noise when you turn your car left or right?
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
