Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-21-2006, 01:37 PM
nls1 nls1 is offline
relay switch location
Hi. Does anyone know where fuel pump relay switch is located on 1995 Ford Thunderbird LX. 4.6 V-8. Thanks for any help.
Old 01-21-2006, 04:41 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: relay switch location
The relay is inside the Constant Control Relay Module (CCRM) that is located in front of the air cleaner box. There is a rectangular plug with 21 wires and a screw in the center of it that holds the connecter to the CCRM. The inertia switch is located in the trunk by the drivers side wheel well. Remove the carpet to see it.
The Original 97Bird
Old 01-21-2006, 05:34 PM
Cool Re: relay switch location
I appreciate your help very much. I was given this car because the person could not get it running. I am hoping to get it going.
thanks again!
Old 01-21-2006, 08:00 PM
97Bird's Avatar
You're welcome and good luck with your new Bird.
The Original 97Bird
Old 01-23-2006, 09:46 PM
Okay - besides the fuel pump actually being bad, is there anything else besides the fuel pump relay that would cause the pump to not work? Also, when turning the engine over, the CCRM "clicks". Does this mean it is working properly? Anybody have any input?
Old 01-24-2006, 11:48 AM
97Bird's Avatar
Did you check the inertia switch I told you about? Be sure the red button is pushed in. Do you have 12V at the pump? inertia switch?
The Original 97Bird
