Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-21-2006, 11:32 AM
lambchop lambchop is offline
90 Cutlass Ciera 3.3L
I have a 90 Cutlass Ciera 3.3L V6 that will not start after being parked overnight in foggy, rainy or snowing conditions. I have replaced fuel filter and had a scan check that did not show any codes. Any tips greatly appreciated.
Old 01-21-2006, 04:29 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 90 Cutlass Ciera 3.3L
Welcome to AF! Try this, buy a tub of dielectric grease and coat the coil wire terminals with it and reinstall the wires, do the same thing with the plugs by pulling each one and putting some in the boots and reinstalling them. Finally, under the coils there is an ignition module, pull each coil and put a little of the grease where the contacts go into the back of the coil. This should take care of the starting problem. (You may also want to check the connections to the ignition module and crank position sensor to make sure they are tight.)
