Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 06-16-2002, 01:40 PM
Ham Ham is offline
Nissan Pickup problems
I have a 1992 Nissan pickup- 6 cylinder sports edition, automatic transmission. The problem is that when I accelerate it makes a ticking noise. My friend believes that it is the valves, but I'm not sure. There is also another problem that I think has to do with the transmission. This only happens every so often, but when I go to accelerate after being stopped, it takes a good few seconds for the truck to actually move. Then when I am actually moving, it doesn't shift at all, and the RPM gets really high (obviously). I guess a way to describe it is that it feels like it is slipping back in to neutral. After I bought it last year, I have brought it in to be fixed. The mechanics couldn't really find anything wrong with it, but they replaced the TSP. After that was put in, my truck was running fine for a long time. But just recently it has been starting to run funny again, where it feels like it slips into neutral after stopping. I want to get it fixed before I go off to college. Does anyone have any suggestions, or ideas of what might be wrong with it?
Amy
Old 12-27-2003, 06:45 PM
95pathfinder 95pathfinder is offline
Re: Nissan Pickup problems
I have a 95 Nissan Pathfinder with the same problem, passenger side. It ticks when i accelerate, especially if in gear. It seems to tick at every RPM, it sounds kinda like a motor cycle. Its gotten louder in the past month. Is that the same as your problem? My pathfinder is a stick shift. If I were u I'd get rid of my transmission and its components. If u want reliability get a new tranny. If not, run it till it dies then change out what broke. I'd at least make a when the tranny dies fund.
Old 12-28-2003, 08:50 PM
Hey, go to search at the top right of the screen and in the "search for posts by a specific user" field type in 95pathfinder and you will find an article in the honda forums about a civic with like 39 posts called "weird buzzing when acclering". I've posted in there. It addresses the problem we were having. Check out my posts and the replies that came after it. Everything before my first post is useless.
Old 12-29-2003, 01:19 PM
Arkemn Arkemn is offline
Send a message via MSN to Arkemn
ticking
nissans a noutorious for it after 80,000 miles or earlier you timeing chain is lose but it will last put new timeing chain and you'll be fine nissan uses dual chains on v 6 a kit is about 140 bucks no big an easy do it your self if you know how and thats not so bad you can go another 80 thosand and it won't break and your tourqe converter is bad from what you said take it out have it rebuilt 80 bucks it'll be fine
Razors burn and so do tires
Old 12-29-2003, 06:39 PM
thanx! I'll let everyone know the solution. You're a friggin God
