Old 01-21-2006, 10:43 AM
abaird abaird is offline
coolant burning
How can you tell if you are burning coolant? Other than looking at the level in the radiator and tank. Any smells, smoke, etc.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 01-21-2006, 11:02 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: coolant burning
Light blue out the tail pipe and a sweet smell at tail pipe is a good indication.
I asume you are asking about the 97 K-1500?
If losing coolant run a pressure check on the coolant system and watch for leaks around the intake manifold and water pump and rad.
Also they make a leak dye kit for coolant to find the hard to find leaks.
MT
MT
Old 01-25-2006, 10:17 AM
tom3 tom3 is offline
Re: coolant burning
Pull the spark plugs when the engine has set overnight. Should see a wet one or two if it's leaking into the cylinders. Look at the dipstick when the engine is hot, might see some steaming if leaking into the crankcase, and you might see some water on the underside of the oil fill cap. Usually the leaks are around the intake manifold and you'll see the level in the recovery tank go down over time.
Old 01-25-2006, 01:31 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: coolant burning
If your truck is burning coolant it will smoke white and the smoke will have a sweet smell. The proper way to check it out is to get a block check kit from a part store and have a cylinder leak down test done.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
