Old 01-21-2006, 09:19 AM
boyertownMidnight3 boyertownMidnight3 is offline
Send a message via AIM to boyertownMidnight3 Send a message via Yahoo to boyertownMidnight3
water in my trunk
its a 1st gen-> GSX
im getting water in the truck of my car, i know this is a issue with my car, but im wondering how do i go about taking off my spoiler, becuase that seems to be where the water is coming in at can someone tell me how to take it off becuase im confused.
Old 01-21-2006, 09:47 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: water in my trunk
Nothing in the haynes manual . I'm guessing its coming from the weather stripping along the edges. You could lay in the trunk and have someone pour water over the window and see where it comes from.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-21-2006, 09:57 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
ill go experiment (sp) with my car out back... i believe the plastic pannel pops off and their are screws in the bottom.... ill check it out and get back to ya
Old 01-21-2006, 10:01 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
It's probably the seals, unless there's a way that a trunk on our cars can get out of alignment, i know they can on some GM vehicles.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 01-21-2006, 01:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
its probably the seal at the bottom of the back window. ive had to reseal it on all of mine. havent done it yet on the latest one but it needs it. once you get the spoiler off the trim strip at the btoom of the window just pops off. pry gently at it and then clean all the crap out of the groove and pack it with caulk or silicone. stick the trim back on before it dries completly since some of it usually ends up in the clip spots for the trim.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-21-2006, 11:20 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Simplest thing first, check the two holes on either saide that drain t the ground when it rains, snows, etc.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
