Old 06-16-2002, 11:43 AM
BabyBlu015 BabyBlu015 is offline
Question Dynamat?
Hello,
I recently put a system in my car but my sub makes the trunk vibrate a little when its on. Its not really bad but it bothers me (sounds cheap). I have heard that once you find your problem dynamat installed in the trunk helps and also improves sound. Is this true? Can I easily install it myself? Tips? Are there any other products that work well? Thank you.
Old 07-02-2002, 01:08 PM
xivera's Avatar
xivera xivera is offline
Yes, any sound-deadening (like Dynamat, B-quiet, etc.) will fix any rattles as well as reducing panel resonance and reduce road noise.
It truly helps & improves sound. You can install it yourself if you have the right tools (ie. rolling pad...). Tips: Follow instructions!
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 07-02-2002, 02:37 PM
StageOneGalant's Avatar
StageOneGalant StageOneGalant is offline
Send a message via AIM to StageOneGalant
Dynamat!!!!!!!
Dynamat works great i have it in my trunk... it kills all the rattling... here's a Ghetto Trick.... take a peice of Sponge use double sided tape.. and place it behind u're Liecense plate to kill the rattling there... jus a small peice should do the trick... hehehehe..
95 Mitsubishi Galant
Stage 3 FrankinStein Turbo, RalliArt Headers/Clutch , Custom Kat back exhaust system...etc....(enuff info )
Euribuni Body Kit, 18 in Konig Wildcards.
"Just Because words are free, doesn't mean u can use them Freely."
Winning isn't everything, it's the ONLY thing!!
Old 07-07-2002, 03:24 AM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
lol... that's awesome.. i was hoping i wasn't the only one who used a sponge for that .. lol... that's great
S2000
