Old 01-21-2006, 12:11 AM
venado123 venado123 is offline
Red face 96 s10 wires...
Hey,
When I press the brake the rt turn lamp comes on? What could cause this?
thanks-
-v-
Old 01-21-2006, 02:15 AM
rvolk86 rvolk86 is offline
Re: 96 s10 wires...
Originally Posted by venado123
Hey,
thanks-
-v-
if the insulation has worn off and a connection made between the turn signal and the brake lights, this could cause it. check to make sure the grounds are secure as well.
Old 01-21-2006, 10:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 s10 wires...
Welcome to your first post on AF.
Also check for good ground and good bulbs on front and rear signal and tail lights.
A bad ground or bulb or bulb socket will make the brsake lights and or turng signals go crazy.
MT
MT
Old 01-21-2006, 10:41 PM
Thanks
Thanks, I am going to check it out....for usless info...I just removed the original rear shocks...215,825 with out a change!
Old 01-22-2006, 09:24 AM
MT-2500's Avatar
AF - Advisor
Re: Thanks
If it happened right after rear shock replacement you might look at the wiring in the rear shock area. Also add on trailer light plugin sometimes give connection or wiring problems where they hve been spliced or added in.
Good Luck MT
MT
