Old 06-14-2002, 04:36 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Short Shifter Install, Can I Do It?
I was simply wondering how hard it will be to install a short shifter into my car; could I, a person with little knowledge of cars (but knows basics) be able to put this thing in in a few hours? What all does this installation entail? Also, if anyone would like to reccomend any short shifter brands, feel free. Thanx all :frog:
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 06-14-2002, 05:13 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I just ordered my DC sports short shifter. It should be a pretty simple install...I think you have to unbolt your exhaust (just to move it out of the way), then there's a couple bolts holding the shifter in place from underneath the car. Once those are out, the shifter should drop right out (assuming you removed the shift knob), then it's just a matter of swapping the new one in with new bushings and dust-cap... Shouldn't take more than an hour (including putting the car on jack-stands, etc).
Old 06-14-2002, 06:12 PM
Cool, just two more questions, then I'll be satisfied. Will I need a different short shifter when I get my B16 engine or does that not make a difference? Also, will the bushings and dust caps come with the shifter? If not, where can I get them? Thanx again :frog:
-BMan original
Old 06-14-2002, 06:19 PM
ci5ic's Avatar
I think the short-shifter comes with the bushings, but not the dust-cap. If not, order them from Energy Suspension (www.energysuspension.com)
The shifter should work with your B16, but I think the shifter linkage needs to be shortened or something...
Old 06-14-2002, 08:54 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
i dont know what is easier to install... a short shifter or an Intake?? What im trying to say is that it is REALLY easy and pretty self explanatory when you look at the shifter on what to do.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 06-14-2002, 08:59 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
most short shift kits do not come with the dust cap, but it is a must have. My friends 94 GS-R has no dust cap and when he is cruisin down the hwy in 5th, unless he holds the shifter it makes noise.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-14-2002, 09:12 PM
Call me stupid, but i went to www.energysuspension.com and I couldn't find dust caps. Anyone know any other sites or just exactly where they are on the site? Thanx some more. :frog:
-BMan original
Old 06-15-2002, 12:10 AM
OldSchoolHatch's Avatar
OldSchoolHatch OldSchoolHatch is offline
Send a message via AIM to OldSchoolHatch
What kind of a noise would that make? Because I had my mechanic put mine in and when I'm goin at a high speed or high rpm, and I'm holding the shifter, it feels like a real faint scraping or grinding or something but not when I shift gears. He did lower the exhaust so I don't think it's scraping that or anything, does anyone know what it is?
Old 06-15-2002, 07:09 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i installed my short shifter without taking off the exhaust. i took off my center console. the rest is frrom underneath. the hardest part was squezing the shifter into the shift linkage. mine is a ebay generic. when i put it on i put it backwards so it was facing toward the dash so i had to take it out and do it all over again. i dont remember what tools i needed but it was pretty easy. took me only like half hour to do. but i consider myself a pretty good mechanic.
i never noticed any noise but i havent been listening for it
Old 06-15-2002, 09:58 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Is the dust cap the rubber thing under the boot that goes around the shifter? If so my car already has one so why wouldn't yours?
Anyway from what I have seen you...
jack the car up
Go under and un bolt the shifter from the linkage
Go pull the old shifter from up top (if you leave the knob on it should work).
Drop the new shifter in
Bolt it to the linkage
Done, I guess.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-15-2002, 08:26 PM
man can you do it that way ? if so the way i did it the hard way.
first i took out the center console then took off i guess thats the dust cap. then i went underneath unbolted the shifter from the linkage. then i took off this metal flat piece kind of triangle shaped thing like 3 or 4 bolts. then that flat metal piece drops down with the shifter and took out the shifter from the flat metal piece then install is reverse
i dont think you can do it that way because if you jsut have to unbolt the linkage to pull out the shifter then what stops the driver from just pulling out hte shifter or dropping down the shifter. soemthing holds it in place.
so yeha its pretty easy i didnt use my haynes manual or anything just went under there and started unbolting stuff till the shifter came out
Old 06-16-2002, 12:51 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
I just installed my short shifter, I was replacing a clutch at the same time so it was pretty easy. I already had the exhaust off and the linkage was hanging down so I just popped it in. Dropping a tranny with no tranny-jack or anything is a biatch, and no parts stores carried a pilot tool that worked for my 'rex so we rigged up some shit. If you're ever replacing a clutch in your 'rex make sure that the pilot tool fits the new clutch before you begin, save yourself from what I did.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Short Shifter Installation QuakeWork120 Integra 1 08-10-2003 10:53 AM
Short Shifter Install 99civic03 Integra 1 08-07-2003 12:34 PM
Short Shifter Install HELP! Cruizer2169 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 15 03-24-2002 11:02 PM
Short shifter install KidDragon Engine 4 11-01-2001 06:48 AM
