Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-21-2006, 12:31 AM
Nulifekc Nulifekc is offline
lowering 85 caprice
Im getting my 85 caprice lowered. I need some opinions how many inches, and do I need to change the size of my wheels when I get it lowered.
Heating the coils.
Zac
Old 01-22-2006, 02:41 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: lowering 85 caprice
Heating the coils.
Zac
While I personally don't like seeing people do these to these cars, it is your car and if you want to do it right, don't simply heat the coils. That will lower it, so in that regard, mission accomplished - HOWEVER, and this is a huge one - the geometry on the suspension is going to be way off, and you'll kill your springs. What's wrong with that? You'll bottom it on every bump, you'll wear tires, your handling will go away and your ride will do likewise. The car will also become dangerous to drive at speeds of over 15 miles per hour. If you really want to lower it, you can get special spindles that raise the tire in relation to the rest of the suspension. This will drop the car while retaining factory handling, ride, comfort, SAFETY and longevity. It's really the only way to do it if you don't want to wind up an 'organ donor'.
You can use suspension parts for the '94-96 Impala SS/Caprice (these parts should be readily available) or any suspension part from '77-'96 as they all generally interchange. You should check the caliper location on the spindles due to the two different bolt patterns used (5x5" or 5x4.75").
Old 01-22-2006, 03:32 AM
Alright thanks a bunch ill look into that
zac
Old 01-22-2006, 08:09 AM
CD Smalley CD Smalley is offline
Geeez. Did we not cover most of this already once?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
